My under counter Kitchen Aide icemaker recirculating pump seems at times to be starved for water. Sounds like a boat bilge pump that has pumped out all the water and is just running without pumping. It makes ice fine. Does anyone know a solution to this? I can turn it off a minute or so and then back on and it's ok for awhile, then it starts again.
We are going to need the model number off the unit.
Nat
