Ok, the water continued to run for several seconds after unplugging the washer. It happened every time I tried it. On the replacement parts diagram I see a water level switch (ap2045895). Is this what I need?
Typically the tube will clog within 6 inches of the box but anything is possible. In any case it seems you have a water valve problem. If the water fails to turn off when you unplug the washer the water valve is bad. The water should stop within 2 seconds or less. Part Details - GE Washer water inlet valve, part number: AP3861119
