hello not really sure the age of this dryer. but I was doing laundry and went to place a load in and it just blew cold. I had another dryer do that and it was the therstat and another was a fuse was told on this it might be heater??? was asked to come here to find out what to repair first.
First, do you have a meter? Check to make sure you're getting 240VAC from the outlet. If you are, Can you do a few easy continuity checks?
Hello I do not have a meter but have a friend that does. I have traded it for a loaner dryer for now and that dryer is working perfect and had switched cord to other dryer we are currently using til then.
