I just bought a secondary water valve from AppliancePartsPros. I seems to be the right valve even tho the connections are different. I hooked it up and there is no water flowing from the door water dispencer or the icemaker. I wonder if I got the water lines mixed up. I have the water line that comes out of the primary valve going to a line that goes inside the fridge. I have the water lines that go out from the secondary valve connecting to lines that go outside and up the back of the fridge. One line is thin so there is only one water connection it will fit. The other two are the same size lines. Can anyone describe which connections that each of these lines go to? Thanks, Bruce
