rsking
#1 Posted : Tuesday, November 2, 2010 4:12:45 AM(UTC)
rsking
The freezer coils freeze in one big block of ice. The fan works, the heating element and heater thermostat seem to work OK. The connections appear to br OK. What else is there to check other than the timer control?
#2 Posted : Tuesday, November 2, 2010 5:21:29 AM(UTC)
Replacement parts for ADMIRAL ATB1712ARW Ref - Top Mount | AppliancePartsPros.com
I am not sure how you checked these so below is a full blurb on how to check it out.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 12 in Section 5) till the fans and compressor turn off.
There is usually a hole in the control console in the fresh food side to let you turn the cam. It only turns in one direction so do not force it.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 9 in Section 2) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 12 in Section 2) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
Roger (Refrigerator & Freezer Repair)
by Roger Baker 8/25/2011 5:38:09 AM(UTC)
