AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Washer fills and agitates but dial does not move forward
The washing machine fills with water and starts to agitate. The dial does not advance, and the machine continues to agitate indefinitely. You can manually move the dial from cycle to cycle, and the machine will process each cycle. Is this a timer problem?
Yes check voltage on motor some of those old maytags you could just get the motor
Washer Repair
