My kenmore washer is leaking out the bottom. It starts leaking alot of water when the washer is filling. It does have soap in the water and it seams to be draining from the left front corner. I stopped it and it continued to drain all the water that it had put in the washer thus far. Which is quite a bit of water. It is not quite two years old but warranty has expired:( . Please help. Thank you.
Sounds like your recirculating pump went out or a hole in the hose! Nat
