AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Kenmore Dryer Works On Auto Cycle But Not Timed Dry........
I am working on a Kemore dryer, it cycles fine in Auto Dry, but when I use the Timed Dry cycle the heater comes on, cycles off and never comes on again. Any help greatly appreciated. Thank you.
Mike
Originally Posted by: FDAR  I am working on a Kemore dryer, it cycles fine in Auto Dry, but when I use the Timed Dry cycle the heater comes on, cycles off and never comes on again. Any help greatly appreciated. Thank you.
Mike Mike, Sorry , but based on what I have, there is No difference in the heat cycle, on timed dry versus the auto dry cycles. Other than the timer motor circuit being intermittent on auto dry and constant on timed dry settings, there is no difference in the cycles. I can only guess, Has someone else worked on this unit ? Improper / crossed wires ? Wrong part installed ? My best guess is a timer contact failure, but I'd expect you to have other problems. Good Luck, :) :) :)
Dryer Repair
