I have a Kenmore under the range microwave, model# 665.6060900, my door latch is broken and I cannot see how to replace it. I ordered the part but do not see how Im suppose to get it on. Please help
Originally Posted by: burneyk ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have a Kenmore under the range microwave, model# 665.6060900, my door latch is broken and I cannot see how to replace it. I ordered the part but do not see how Im suppose to get it on. Please help Burney, I take for granted, you mean the latch on the door, not the catch / switch assembly inside the microwave. These instructions, should get you through the repair, Good Luck, :cool: :cool: :cool: 1. Unplug microwave oven or disconnect power. 2. Open the microwave oven door. 3. Pry the choke cover away from the top door pin, and remove the top pin from the pivot bracket. Lift the door off the bottom bracket, and remove it.
4. Place the oven door front side down on a padded surface. 5. Remove the choke screws from the door frame
6. Starting at the top right corner , pry the choke cover out with a putty knife, and unsnap it from the choke. Only remove the top, bottom and right sides of the choke cover at this time. You will remove the handle end of the choke cover later.
7. Starting at the top edge of the door near the center and working clockwise, use a putty knife, and pry the latching tabs of the choke out of the door frame slots. Lift the choke as you release the tabs so they do not snap back into the slots. NOTE:
When you reach the handle side of door, pull both the choke and the choke cover away from the door frame, and then separate the two components
8. To remove the door switch actuators from the choke, remove the screw from each actuator
REASSEMBLY NOTE: When you reinstall the door on the oven, insert the top pin into the pivot bracket and press down on the pin until it snaps into place
