texaszinnia
#1 Posted : Tuesday, October 28, 2008 6:32:58 PM(UTC)
texaszinnia
the ram on my kenmore model # 665.13601790 will not raise. the compactor runs, there is power to the compactor. is this something I can fix myself or should I take it to be repaired?
Thanks,
texaszinnia
#2 Posted : Thursday, October 30, 2008 11:50:56 AM(UTC)
texaszinnia,
Remove the unit from the cabinet, put it on a side, remove the bottom cover and check the chain and gears. Post the results.
texaszinnia
#3 Posted : Sunday, November 9, 2008 5:01:47 PM(UTC)
texaszinnia
Thanks for your help Gene, it was the chain it had popped off of the gears. My son put it back together and it works like a charm!:D
texaszinnia
#4 Posted : Sunday, November 9, 2008 9:04:20 PM(UTC)
You are welcome. I'm glad you were able to fix it.
