The timer knob on my dryer has split where it slips on the shaft and therefore slips instead of turning the shaft. I ordered the knob but the part is not correct for the dryer. The dryer has never been serviced so the knob is the original. Any suggestions?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Thw problem is the part in the picture is not what is on the machine. The part currently on the machine is a one part knob.
Can you get the numbers off the timer.
Then using the this it may be possible to find what knob goes with that timer. |
