Don Ging
#1 Posted : Tuesday, October 28, 2008 10:36:33 AM(UTC)
Don Ging
I have a Tappan combo unit (TGO346BCDC OEM is Fridgedaire). The top oven has no gas flow. The ignitor glows and the upper oven indicator works. The range burners work, the lower oven works, the broiler works. Could this be a problem with the dual gas safety valve???
libertyappl
#2 Posted : Tuesday, October 28, 2008 10:40:42 AM(UTC)
libertyappl
Most likely the ingnitor isn't getting hot enough to open the valve and light the gas. This sometimes happens if the ignitor develops a hairline crack.
Nat
