2 yrs. ago, replaced water level switch. Once again, washer over filling on all load setting. Replaced water level switch (2nd). Now, still often over fills on all load sizes and will often aggitate on rince with no water in tub. Also, won't spin after rince cycle. Only when switch is moved from one load size to another. thanks !
Check the presure switch tube, if it has water in it or has a pin hole or crake the washer could over flow and could also be telling the machine that it is full of water for the rinse cycle. Does the timer continue to advance when it is supposed to be spinning and not? Nat
Thank's, the time does advance into extra care with extra care off. Checking hose now. Rob
Hey Nat, You Sir... are the man. It turns out that where the tube conects to the "box" at the bottom of the tub.The tube and nipple were plugged\restricted. Thanks so much. Rob For sale: presure switch, almost new
lol.......Glad you figured out. But I guess I don't mind being called "the man"....lol
Nat(Natalie)
Nat(Natalie)
