King
#1 Posted : Tuesday, September 25, 2007 9:43:12 AM(UTC)
King
I have searched all sources for a replacement door seal set. The problem is the unit is too old. The model number doesn't appear in any data base. I would give up on this but it still works fine for a cottage icebox. I've also tried to source by seal dimensions to no avail. The seals measure 13.5" x 30.5" & 39" x 30.5". Anyone got one sitting on the shelf?
#2 Posted : Friday, September 28, 2007 1:54:58 AM(UTC)
Most parts places sell cut to fit gaskets. Just call appliancepartspros to order one. These gaskets are a bit of a problem to put on correctly so you will need advice when you get it.
