  I have just installed this gas valve on my furnace and I'm now reconnecting the red and white wires from both the powerpile and the thermostat. I need to know where the red and white wires connect on the terminal block. I know the terminal is marked PP and TH, for powerpile and thermostat, but I need to know where the red and the white cables connect for each.
Make and model number of unit you installed on.
Peerless G560-W-S is the unit I installed the valve on.
Originally Posted by: lqbano  Peerless G560-W-S is the unit I installed the valve on. Try IO&M Manuals
