Problem: Tub won't spin to wring out load
Discovered problem when the washer was supposed to be in the final spin cycle. The water was pumped out; the motor was running; but the tub was not moving. I shut the unit off and then retried a few times to see if it would spin...no luck, it just pumped out the remaining water in the tub. Next I tried to see what would happen at various points of a complete wash cycle...nothing happens. I assume nothing can happen because there is no water in the tank! Any help or ideas out there? Thank you, Matt
You have a busted coupler, just remove front panel and motor. You will need to replace the motor coupler. Click on your model # above to order it.
Good morning Richappy, Thank you for the advice. Fortunately, it is an inexpensive part. Matt B
