sdsprigler
#1 Posted : 14 years ago
sdsprigler
Frigidiare Gallery Front Loading Washer Spewing water from the front it's coming out only on the rinse cycle when it drains not fills it is also coming out of the soap dispenser just replaced the motor control and now this - help please - I keep seeing posts about a boot door kit but no specifics
sidfink43
#2 Posted : 14 years ago
sidfink43
This is a real mystery if the water comes out only on the rinse cycle and not on the wash cycle. The only thing I can think of is that something prevents the wash cycle water from completely draining, and the extra water in the drain flow plus the rinse water causes it to overflow.
I would start by cleaning out the pump and drain hoses, both internal and external and then see what happens.
