Replacement parts for FRIGIDAIRE CER3600AS1 Frigidaire/electric Dryer | AppliancePartsPros.comHere is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/131953900.pdfYou keep referring to 120 volts, it is 240 volts that is for the heater
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
[COLOR="Blue"]my dryer wont heat i have checked all heat sensors and element and all sensors ohm to 0 and the coild at 1.[/COLOR]
Not sure what you are measuring (coild). If it was the heating coil then 1 ohm is way too low, it should be about 12 ohms.
[COLOR="Blue"]I also checked the timer motor and it is supposed to be at 4.4ohm and i got 5ohm on the test?[/COLOR]
Only thing I see on the wiring diagram at 4.4 is the resistor and this should be 4,400 ohms not 4.4 ohms. This is not the timer motor winding.
[COLOR="Blue"]So finally i did a live test and all sensors open and are sending 120v through them, I also checked the coil and it has 120v coming to it from both wire leads and 120v on the coil wire itself?[/COLOR]
All sensors should be closed (0 ohms), not open (infinite ohms).
The 120 volts does not tell you much as the heater requires the full 240 (L1 to L2 voltage).
To check your thermostat's and fuses
Unplug the machine.
Always remove one side of any device you are measuring. This prevents you from reading an alternate/parallel circuit path.
Since you are checking for 0 ohms use the most sensitive meter scale (200 ohms on most meters.
Before starting short the two meter leads together so you can see what 0 ohms actually reads on the meter. Many times a meter will have a small offset.
