2 Pages12>
jeansto
#1 Posted : Sunday, October 26, 2008 6:07:00 PM(UTC)
jeansto
kenmore side by side fan working, compressor hot, when compressor tested with unit off checked for open windings by ohms found resistence leg to leg, do we need a new compressor?
v2k04
#2 Posted : Monday, October 27, 2008 3:36:00 AM(UTC)
v2k04
maybe just a relay
kayakcrzy
#3 Posted : Monday, October 27, 2008 4:40:15 AM(UTC)
kayakcrzy
Its a Kenmore, the overload and relay combination have a history of going out. I bet that is it. Tom ApplianceEducator.com
icehouse
#4 Posted : Monday, October 27, 2008 6:08:35 AM(UTC)
icehouse
Hey Tom, see you are over here also. :D
kayakcrzy
#5 Posted : Monday, October 27, 2008 3:10:38 PM(UTC)
kayakcrzy
You now me, the Appliance Guru. Tommy boy
icehouse
#6 Posted : Monday, October 27, 2008 3:22:11 PM(UTC)
icehouse
Yup. Sheilas forum is loaded with garbage ads.:eek: What 's up with that. :confused:
Oxebo69
#7 Posted : Monday, October 27, 2008 4:01:58 PM(UTC)
Oxebo69
You have 3 pin (triangle) you have to check with a Ohm meter how to check:
Common : Is the biggest resistance
Start: Medium
Run: Smallest
If you see that all of them are almost the same it means shorted or if you touch one of those pins with a pipe & you have a continuity it means its shorted 2.
Hope it was Helpful! :)
icehouse
#8 Posted : Monday, October 27, 2008 4:30:16 PM(UTC)
icehouse
Start: Medium
Run: Smallest
:confused: Start is the largest resistance, not Common.
The total resistance between Run and Start should equal the sum of Start to Common and Run to Common.
Example: C to S = 5 Ohms, C to R = 2 Ohms, Then C to S = 7 Ohms
Testing for Grounds: Using an Ohmmeter place one probe on a good ground
such as the ground screw on the compressor. The other probe should then be placed on one of the pins as so stated. If you get a reading, the compressor is grounded.
Testing for open windings: Using an Ohmmeter take the leads and test between any two pins. Reading infinity compressor has open windings.
Testing for shorts: Using an Ohmmeter, place the leads between any two pins. Reading zero shorted compressor.
So much for "Compressors 101" :)
v2k04
#9 Posted : Tuesday, October 28, 2008 3:05:05 AM(UTC)
v2k04
nicely done Icehouse lol
icehouse
#10 Posted : Tuesday, October 28, 2008 3:15:03 AM(UTC)
icehouse
Thanks. I love what I have been doing for forty years now. :) God I'm getting old. :eek:
2 Pages12>
