forna
#1 Posted : Wednesday, October 27, 2010 3:46:39 PM(UTC)
forna
My igniter doesn't glow. Igniter is good. Checked all connections. Can't find any thermo fuses. Found a thermostat l300 Ge part # ap 2042686. Can this be my problem? Is there any way to test it? Or what else could it be? THANKS
#2 Posted : Wednesday, October 27, 2010 4:12:06 PM(UTC)
You have to check for continuity the thermal fuse (#272 on the diagram).
- The thermal fuse Part number: AP2042696
whsydddy9
#3 Posted : Wednesday, October 27, 2010 4:19:38 PM(UTC)
whsydddy9
Be SURE to NOT TOUCH the igniter with your fingers...the oil from your body will cause a hot spot and burn out the igniter. Good Luck!
samsung igniter doesn't glow but is good (Dryer Repair)
by bushman64 8/5/2017 1:28:14 PM(UTC)
