gamerguy2002
#1 Posted : Sunday, October 26, 2008 9:50:38 AM(UTC)
gamerguy2002
For about 2 weeks now my whirlpool washer has been flooding massive amounts of water out of the bottom of it this usually happens in-between the fill and spin cycle. I have no idea whats going on this has never happened before. Can anyone give me some advice on whats going on? Thank you.
SublimeMasterJW
#2 Posted : Sunday, October 26, 2008 7:31:14 PM(UTC)
SublimeMasterJW
Slow drain pipe:D
kayakcrzy
#3 Posted : Monday, October 27, 2008 4:37:43 AM(UTC)
kayakcrzy
You could have a leak in the hose, or the pump has a leak in it. The best thing to do is unplug the washer, and pull it away from the wall and lean it back. Then to check the pump, feel around the front of it, and then behind it, and see if you feel water. If so replace it. Also check the clear pressure hose that mounts to the side of the tub, and make sure it is on. Tom ApplianceEducator.com
