I have one kenmore gas dryer Model# 110 97382100 problem is no heat and no flam i have replas allmost all parts like from Themostat,Solenoid coilkit,gas valve,flame sancer, thermal fuse,igniter etc still no flan and no heat in dryer
Check your control thermostat. It is mounted beside the fuse. If it is open the heat will never work.
No!! Take the back off the dryer, and right next to the control thermostat, that The sublime Master mentions, is the thermal fuse. It is white in color, and is about an inch and a half long, and a half inch wide. Make sure the dryer is unplugged, and take the 2 wires off of it, and put the terminal ends of the wires together, and put some tape around it, so it does not hit metal, and then plug the dryer in and see if it works. If so, DO NOT RUN the dryer with it jumped out. It is the only conponent between you and the dryer burning down the house. Let us know. Tom ApplianceEducator.com
