1) Motor does not turn on. When cycling through various selection options and pressing corrospondng buttons, motor will not turn on. At the "pots/pans" option, you hear a motor hum but it will not start.
2) About 2" of water is standing in base of dishwasher. Does not drain.
Suggestions would be appreciated.
Thanks,
Originally Posted by: bpd8523  1) Motor does not turn on. When cycling through various selection options and pressing corrospondng buttons, motor will not turn on. At the "pots/pans" option, you hear a motor hum but it will not start.
Thanks, Bpd, Sounds like a bad motor relay or motor, as best I can tell. Part number: AP3154718
And the motor pump assembly has been discontinued by the manufacturer. There's not a lot of technical information, or parts for a unit this old, But that's where I'd start, were it me. Good Luck, :) :) :)
