Does anyone have a schematic or know the wiring for this 20 year old dishwasher? It has a black single wire and then 3 colored wires going to a white plug. I am assuming they change speed and direction. I just need the two for most power. Thanks, Radarguy
Did you check to see if yours is in a plastic bag, attached to the inside of the kick panel?
Yes I did and it is not there. I purchased this new and installed it myself and have even replaced the motor/pump assembly but cannot find the diagram. Any help would be appreciated. Thanks for the reply.
