Bondy
#1 Posted : Friday, October 24, 2008 6:38:26 PM(UTC)
Bondy
I just cleaned the lower oven today (self cleaning) and once the cycle was completed it started to beep and a code F1-4 was displayed on the panel. I tried to cancel but it won't. The upper oven door unlocked but the lower oven door will not unlock. When I try pressing any of the buttons on the panel such as cook and so on it just beeps and says LOCKED on the panel.
Any suggestions, Thank you.
#2 Posted : Monday, October 27, 2008 8:36:05 AM(UTC)
Hi Bondy,
"F1-4" error code means "Runaway temperature, lower oven".
The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug.
If the resistance reads wrong then replace the oven sensor.
If there is nothing wrong then the control board has to be replaced.
- The part number for the oven sensor is AP204836
- The part number for the control board is AP204841
Here are the break down diagrams for the Maytag Gemini range Model MER6770AAB
P.S.You can find the complete instructions on how access the lower oven door lock in the Service manual..
