MrsP111
#1 Posted : Friday, October 24, 2008 4:00:17 PM(UTC)
MrsP111
The elements for both bake and broil stopped working yesterday. Thought I might need to buy new elements, but then thought it odd that they would both stop at the same time. Stovetop works perfectly, no problem. I've been told that I need to buy a new control board / clock? Costs a bit more than I have...so just wondering if there is anything else I can do....replace wiring...something? Thanks for your help!
#2 Posted : Saturday, October 25, 2008 4:01:38 PM(UTC)
Pull the range out, remove the rear cover and check all wires to the heating elements. If there is nothing wrong then the control board (aka a clock) has to be replaced.
- The part number for the clock is AP3586196
In case you would not be able to use the old overlay, the part number for the overlay is AP2126496.
