easterja
#1 Posted : Sunday, October 24, 2010 11:21:34 AM(UTC)
easterja
Do I need to use an adhesive in addition to replacing the retaining screws when replacing the refrigerator and freezer door gaskets?
Thanks for your response.
J. Easter
magician59
#2 Posted : Monday, October 25, 2010 6:26:15 AM(UTC)
magician59
No adhesive is required. Just use the screws. Be sure to follow the directions that come with the seal. Although it seems very simple, gasket replacement is more difficult to get right than it appears. Sometimes a blow dryer helps to remove the wrinkles and help the seal to adjust correctly. Don't remove the old gasket all at once: Remove ablut a quarter of the screws at a time, and install the new gasket as you work your way around the door.
easterja
#3 Posted : Monday, October 25, 2010 11:23:10 AM(UTC)
easterja
Thanks!!
JAE
Advice on replacing Monogram refrigerator door gasket (Refrigerator & Freezer Repair)
by TerryY 10/14/2016 6:30:50 PM(UTC)
Refrigerator door gasket install problem (Refrigerator & Freezer Repair)
by hwkugol@gmail.com 4/2/2012 10:24:40 AM(UTC)
Roper refrigerator door gasket instruction (Refrigerator & Freezer Repair)
by veggiemuffin 8/20/2011 11:36:02 AM(UTC)
Refrigerator door gasket replacement (Refrigerator & Freezer Repair)
by Tom Carty 6/23/2011 9:22:00 AM(UTC)
How do I replace refrigerator door gasket? (Refrigerator & Freezer Repair)
by brianwbates 9/27/2010 10:39:27 AM(UTC)
Refrigerator door gasket (Refrigerator & Freezer Repair)
by LarryBALF 8/18/2010 10:56:49 AM(UTC)
Replacing refrigerator door gasket seal (Refrigerator & Freezer Repair)
by mkibsum 2/28/2009 11:34:35 AM(UTC)
New refrigerator door gasket is wrinkled and doesn't seal (Refrigerator & Freezer Repair)
by jayclen 1/29/2009 3:47:24 AM(UTC)
Refrigerator door gasket install (Refrigerator & Freezer Repair)
by shark 3/17/2008 9:47:37 PM(UTC)
