Pooler
#1 Posted : Saturday, October 23, 2010 10:33:03 AM(UTC)
Pooler
My oven will heat up to temp with no problem, the problem is when it needs to relight to keep desired tempurature it clicks twice than nothing happens. Broiler works just fine...a tech told me to replace the Oven Burner Assemply, I wanted to double check to ensure thats correct.
mamaswans
#2 Posted : Tuesday, May 6, 2014 6:46:27 AM(UTC)
mamaswans
I am having the same problem on my Whirlpool range... Did you get an answer? If so, please share!!! Thanks!
