KRIECKM
#1 Posted : Saturday, October 23, 2010 6:43:41 AM(UTC)
KRIECKM
Fridge hasnt gotten cold in 2 days..50 degrees..freezer works fine. I dont hear any fans going at all..I took the panel off in freezer and noticed the fan above coils was not turning..as if it was frozen..actually it was turning but not continuous..Help
#2 Posted : Saturday, October 23, 2010 10:02:58 AM(UTC)
Replacement parts for FRIGIDAIRE FRS26LF8CS3 Frigidaire/refrigerator | AppliancePartsPros.com
I would replace the fan (Item 13 in Section 5).
It is required to blow cold air into the fresh food side.
If you want to double check this, measure the voltage going to the fan. If it is 120 volts and the fan does not run correctly, it is toast.
