Earlier in the week, I noticed my refrigerator is running much too long at a time. The freezer is set on 4 (1 = warmest, 7 = coldest). If the refrigeration compartment is set on three, it runs for hours on end. If the setting is changed to 2, it won't come on for hours.
It's also noiser that usual when running, and there's a low volume, upper mid-frequency "singing" noise as well.
The doors are sealing properly, and neither the freezer nor the refrigeration unit is overcrowed.
Any information, suggestions, hints -- anything! -- will be most welcome.
Thanks,
Jim
THIS FORUM IS DEAD!!!!!!! |
Denman,
Thanks for the quick response. I finally had time this (Sunday) afternoon to better check everything out and discovered the condenser fan works only with the assist of a quick hand turning.
Guess I'll be ordering one, eh? lol.
Thanks again,
jim
