mitch8
#1 Posted : Friday, October 22, 2010 12:35:37 PM(UTC)
mitch8
I have a gas dryer that doesn't produce any heat - everything else appears to be running properly. I've checked the sensor (measures about 12 ohms when disconnected to the system; the igniter measures about 60 ohms; and one of the solenoids (the 2-connector one at the rear) measures infinity. I suspect this is bad. The other solenoid with 3 connectors measures 1365, 1960, and 595 ohms taking all the combinations into account.
My question is how do the solenoids get removed from the assembly? Do you have to take the whole assembly out?
Thanks,
Mitch
Joe / APP Team
#2 Posted : Friday, October 22, 2010 1:04:13 PM(UTC)
Joe / APP Team
Thanks,
Mitch
Mitch,
Sounds like a bad coil set to me,
You should be replacing both coils.
Part number: AP2150379
Not that hard a job,
There are two phillips head screws that attach the metal coil retainer bracket to the valve body, remove the screws and retainer, and the coils slip up and off the plunger of the gas valve.
UserPostedImage
There is a metal sleeve on the plunger of the three prong coil, make sure it remains, or gets installed on the plunger before you button it up(sometimes it sticks to the inside of the coil).
Good Luck,
mitch8
#3 Posted : Saturday, October 23, 2010 9:55:13 AM(UTC)
mitch8
Thanks Joe - appreciate the feedback. Never having done this kind of repair, it's always reassuring to have someone experienced out there to allay my fears ;-)
Joe / APP Team
#4 Posted : Monday, October 25, 2010 5:28:52 AM(UTC)
Joe / APP Team
Mitch,
Thats what we're here for, To help as best we can.
Once you're into it, you'll be amazed at how quick, you'll have it repaired.
You're welcome,
