My oven won't heat to even 250 degrees even if I have it set at 500! This happened this summer one time, then it magically started working again. Would this be the heating element?:confused:
If it works fine now then it's not much what could be done at this time. Keep use it until it'll break. Here are the break down diagrams for the Tappan range Model 31-2759-23-03Gene.
