rmachor
#1 Posted : Friday, October 22, 2010 9:06:00 AM(UTC)
rmachor
At Spin Cycle, It Starts Spinning,the Whabble And Shakes, Make Sure Load Is Balance, Even A Small Load, Start Spin Cycle, Starts Too Spin, Ther She Goes, Whabble Time. What Cause This.
rmachor
#2 Posted : Friday, October 22, 2010 9:11:21 AM(UTC)
rmachor
I HAVE CHECK THE BALANCE OF ALL LOADS
#3 Posted : Friday, October 22, 2010 11:09:03 AM(UTC)
Remove the front panel and check all suspension springs.
Make sure the washer legs are properly adjusted and the washer is leveled properly.
Here are the breakdown diagrams and Replacement parts for MAYTAG HAV2558AWW Washer - Top Loading | AppliancePartsPros.com
In case it would not help post the serial number of the washer.
