I noticed the freezer was not freezing. Neither was the frig part. I took out the compressor and it does rattle (from what I have read, that means it's bad). What do I need to do to fix it. A compressor is expensive (262.00). Do I have any other options? Thank you.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  If you replace the parts Mr. Denman suggested, and the compressor does not kick over. Try putting a hard start kit on it. Maytag compressors are known to lock up. The part # for the hard start kit is RCO-410. The directions are on the part. I always go for the hard start kit on that product. Never the overload and relay!!! Tom ApplianceEducator.com
I didn't cut the lines to the compressor. Your right, I disconnected the relay and that rattles. I did see that the specific maytag frig has a recall on the relay and a person is coming to look at it Saturday (and it would be free). I hope that's what it is. You can shake the compressor and it does rattle though?
[COLOR="Blue"]You can shake the compressor and it does rattle though?[/COLOR] I don't like the sound of the above but will keep my fingers crossed for you. |
Do you think it is the relay then? I hope so, I will find out Saturday 12-5pm. I hope it's just the relay.
