My Maytag Electric Glass Top Oven Digital Display went out. The light still works, the cooktop still works, but no clock or oven. I checked the oven elements and they look fine, I did an ohm reading on both elements and they looked fine. Is it possibly a bad circuit board? If so is there anything I can check so I don't burn up another one? Thanks for your help. Shane
NO!! Replace the board and you should be all set!!!:)
