Valkern
#1 Posted : Thursday, October 21, 2010 6:46:05 AM(UTC)
Valkern
Front Laoad Washer is displaying error code F28 and that code is not explained in the manual.
Joe / APP Team
#2 Posted : Thursday, October 21, 2010 9:14:57 AM(UTC)
Joe / APP Team
Val,
The F 28 error, indicates a communication problem between the CCU (control board in the upper area under the top).
And the MCU(motor control board) on the bottom base of the unit.
Check for loose and damaged wires from one board to the other, check the wires from the MCU to the motor for the same.
You will most likely need a MCU, if the wires and harness are OK.
Part number: AP3968010
Good Luck,
kenmore he3t, error code f28 (Washer Repair)
by bleonard 11/19/2012 11:15:17 AM(UTC)
