I just replaced the refridg. gasket and now the door seems to be warped. It will not close at the bottom left side which is the same side the door handle is on. What could be the problem and solution?
with door still hanging on frig loosen all screws close doorkinda jiggle push whatever till it seals all the way around, gently real soft open door start at the top do each corner then each corner on bottom then each side in middle then alternate from side to side all the way down then to the top and bottom. then close door see how it seals if it still isnt even tweek the door a little bit like grab the top of door and put your knee or foot in bottom and pull a little till it does it's hard to explain hope you get the picture what I'm tryin to say then go over it closed with a hair dryer or heat gun careful not to melt gasket then rub silicone grease or similar all around gasket it should seal.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Lifegard74 replied by email:
"Thanks! That is what I did after thinking about it longer. And, It worked."
