chuck999
#1 Posted : Tuesday, October 21, 2008 10:30:28 AM(UTC)
chuck999
This week our top oven would not heat up to the desired temperature. The next day it worked. The next the temperature would jump back and forth as it preheated. Today it would not heat up high enough even though the display said it had reached the desired temperature. Bottom oven is working fine - for now. Any suggestions.
#2 Posted : Tuesday, October 21, 2008 10:11:02 PM(UTC)
How did you measure the temperature?
