tblouise
#1 Posted : Tuesday, October 19, 2010 9:33:19 AM(UTC)
tblouise
Dishwasher pumps water in and never starts the washing cycle.It just pumps it right back out.
#2 Posted : Wednesday, October 20, 2010 3:48:58 AM(UTC)
Replacement parts for General Electric GSD2230F00WW Dishwasher | AppliancePartsPros.com
For reference look at section 3 in the parts.
Remove the kick plate.
You will see a solenoid mounted on the left hand side of the pump assembly (Item 497). This is the wash/drain solenoid. It operates a flapper valve in the pump housing. This valve either directs the water up to the wash arms (solenoid plunger up) or out the drain (solenoid plunger down).
It sounds like the plunger is stuck in the down position.
This could be caused by a number of things, with luck the spring that pulls it back to the up position has just come off.
Move it up and then check that it can be moved down and it will return to the up position by itself.
If the springs are good and it will not return up you may have something jamming the flapper valve.
If it is difficult to move or stuck then the solenoid has probably overheated and melted the plastic in the solenoid. You will have to remove the solenoid and check it. If this is the problem then odds are that you will need a new solenoid and a new timer.
The reason is that the timer contacts that supply power to the solenoid are sticking closed and keeping the solenoid powered for too long.
The way it is supposed to work is. The timer supplies power to the solenoid for about 5 seconds at the start of a drain cycle. This pulls the solenoid down into the drain position. The water pressure then holds the flapper valve in the drain position till the machine is empty and then the springs pull the solenoid/flapper back to the wash position.
tblouise
#3 Posted : Wednesday, October 20, 2010 5:17:33 AM(UTC)
tblouise
I cannot find the part on the parts list that I need.
I ended up finding it,thanks so very much wil be ordering and hope it fixes it.I looked underneath the dishwasher and this exact part is actually leaking and hopefully will fix the problem.Thanks so very much.
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
