I used the self cleaning function, and when done the do would not unlock. How do I get to the mortor to replace it? Is it under the cooling fan?
Thanks, Dan
Hi Dan, The first thing I would do is restart the self clean like you are going to run it again. Keep it "on" for a minute, then turn it "off'. In most cases it helps to unlock the door. Here are the break down diagrams for the GE oven Model ZET837SBSSGene.
