shanlee
#1 Posted : Monday, October 20, 2008 6:46:01 PM(UTC)
shanlee
the oven will preheat but will not reach desired temp.you can see the short flame on the burner tube shouldn't you see the flame spread out across the bottom of the oven ? also top burners will not ignite you can hear the igniters clicking but no fire:confused:
#2 Posted : Tuesday, October 21, 2008 1:21:08 PM(UTC)
Originally Posted by: shanlee Go to Quoted Post
...also top burners will not ignite you can hear the igniters clicking but no fire...
Would the top burners light up with matches? How good is the flame in that case if you light up all four burners together?
shanlee
#3 Posted : Tuesday, October 21, 2008 2:28:04 PM(UTC)
shanlee
all 4 top burners flame is fine when all lit 1 burner on the back left will still lite without using matches. what do you think about the oven also.
#4 Posted : Tuesday, October 21, 2008 10:29:39 PM(UTC)
Most likely the problem is a bad oven igniter as well as burners igniters.
- The part number for the oven igniter is AP3104565
Part numbers for burner igniters aka spark electrodes are different for different burners. You can find them through the break down diagram for the Whirlpool range Model SF325PEEW0
shanlee
#5 Posted : Wednesday, October 22, 2008 1:56:59 AM(UTC)
shanlee
please explain ! why will oven go ahead & light on preheat but not reach full temp? I replaced the ignitor several years ago, the oven wouldn't even light at all then. I'm not second guessing you just curious.
thanks shanlee
shanlee
#6 Posted : Wednesday, October 22, 2008 2:05:33 AM(UTC)
shanlee
after preheat timer sounds you can see only short flames in oven the whole time, during preheat and after the flame size never changes!!
