#1 Posted : Monday, October 20, 2008 4:50:59 PM(UTC)
Refrigerator compressor works sometimes, but the damper motor oscillates back and forth and the evaporator fan never works. Suspect bad electronic board in the back. Defrost seems to work ok.
Should I replace the board and evaporator fan??
Thanks in advance.
#2 Posted : Tuesday, October 21, 2008 11:25:53 AM(UTC)
Hi Rich,
Hopefully this tech sheets would help you to perform the troubleshooting.
#3 Posted : Tuesday, October 21, 2008 12:53:16 PM(UTC)
Thanks Gene, will copy this test procedure.
