david&shirin
#1 Posted : Monday, October 18, 2010 4:23:33 PM(UTC)
david&shirin
Hi, Our Microwave oven just went dead/Blank screen.
We checked the two fuses inside and they both work OK, next step
would be to check the Thermistor. Does anyone know how to tell if
a thermostate works ok or not? do you have a way of checking it?
Thanks,
DS
Joe / APP Team
#2 Posted : Tuesday, October 19, 2010 7:43:46 AM(UTC)
Joe / APP Team
Thanks,
DS
DS,
In most cases(98% of the time) a thermostat either works or not.
The best way to check a thermostat is to check for a resistance circuit or Voltage through the component, using a meter.
Part number: AP3873826
A thermistor, is similar to a thermostat, but has a specific resistance, usually based on temperature, and has a wide variance in readings which inputs to the control, which is looking foe the input, to determine what the contol needs to do.
Before you go too far, You should probably check the Magnetron Thermostat, for a closed circuit, In most cases that thermostat is a "one shot" like a fuse and will shut down power if or when it opens.
As a last resort, you can "bypass" the component using a "jumper" wire, but that is a last resort and could be somewhat dangerous, if you do it wrong.
Hope that helps,
david&shirin
#3 Posted : Tuesday, October 19, 2010 4:32:29 PM(UTC)
david&shirin
Thanks Joe,
that's good info, we will check.
Joe / APP Team
#4 Posted : Wednesday, October 20, 2010 5:33:14 AM(UTC)
Joe / APP Team
Thanks Joe,
You're very welcome,
We hope it helps,
