scotth1
#1 Posted : Monday, October 18, 2010 2:48:52 PM(UTC)
scotth1
Kenmore elite French door, freezer on the bottom, freezer works fine, refrigerator is not working, the control panel on the inside top will not keep temp for the refrigerator but does for the freezer. any suggestions?:confused: Scott
kayakcrzy
#2 Posted : Tuesday, October 19, 2010 3:26:56 AM(UTC)
kayakcrzy
Open up the freezer door, and see if the fan is running in the freezer. If not, it will most likely be the defrost thermostat, mounted on the evaporator coil, on the top right hand side. Also look on the back wall of the freezer, and see if there is a frost build up. Tom ApplianceEducator.com
