Before we get too far along in this, we're going to need a model number to help you diagnose and fix your oven. However, you can start by checking the power at the outlet. If it's electric, you need 240VAC at the outlet. If it is a gas oven, look for 120VAC, with the correct polarity (hot, neutral, and ground in the right spots.).
