cartoad
#1 Posted : Monday, October 20, 2008 11:15:46 AM(UTC)
cartoad
Thing quit running about a month ago. called a local repair shop and he had me turn the defrost timer and it started running. so I replaced the timer. Now it stops running but if you bump it it will start. sometimes simply opening the door is enough to start it up. it will go a day or two then need to be bump started again.
It seems like a poor conection or a sticky relay. any idaes? thanks
libertyappl
#2 Posted : Monday, October 20, 2008 11:16:56 AM(UTC)
libertyappl
I would check all th connections. start with the defrost timer.
Nat
