what is porcedure to test the two speed motor ? I think one speed is not working causing one wash cycle to be skipped. Timer works, drains fine. Normal cycle final spin/drain does not work even manually. Other cycles work normally except fro skipping the second wash/agitate cycle
Most likely the problem is a bad timer, not the motor. Also I would check if it fills with cold water. Here are the break down diagrams for the Whirlpool washer Model LA8580XWW2Gene.
