I have a Kitchenaid KERC507YWH0, and all of a sudden the oven and broiler do not work and the convection fan is not work. All of the burners on the electric cooktop work, the control panel works and the oven light works. Is there a part that might control power to all three of these (i.e. a fuse)? Any help is greatly appreciated!
Pull the range out, remove the rear cover and check the fuse (#9 on the break down diagram) for continuity. - The part number for the fuse is AP3026588 Here are the break down diagrams for the Kitchen Aid range Model KERC507YWH0Gene.
