the drier quit working in the middle of a load the timmer works belt is good there is electricity to the motor fuses are good when you push the start button nothing happens no noises or anything
Originally Posted by: ten  ...there is electricity to the motor...when you push the start button nothing happens no noises or anything If there is 120VAC to the motor then the motor is bad. - The part number for the motor is AP3094245 Here are the break down diagrams for the Whirlpool dryer Model LER8857EQ2Gene.
