agitator wiil not turn this machine is a 20 lb. capacity, 7 cycle unit. what would be economical to fix . thanks
does it spin and drain? Nat
washer does not spin but it does drain
Originally Posted by: libertyappl  does it spin and drain? Nat it does not spin but it does drain
Check your coupler, located between the motor & pump, chances are it's broken. Here's the breakdown to your machine. Model LST7233DQ0Nat
